  • SN95 4.6L Mustang Tech
Removing front spring isolators
  • Thread starter Thread starter LI98GTStang
  • Start date Start date Jun 23, 2006
LI98GTStang
1,715
L.I., NY
Jun 23, 2006
  • Jun 23, 2006
Looking to remove the front spring isolators to bring down the front end just a touch. Question I have for you guys, is there any way to easily remove the top spring isolators? For example, can I use spring compressors in place to compress the springs and get at the isolators for removal? I did the spring swap, so I know what I would have to do to it the long way. I'm hoping I can get away with a shortcut here. Thanks.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 24, 2006
  • Jun 24, 2006
No shortcuts that I know of...bump for ya
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jun 24, 2006
  • Jun 24, 2006
None that i know of but im sure you know that its not all that hard. I removed mine and have had no extra noise or anything. It also made the car look 100 times better since i had sagging ass Eibach Sportline Springs
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jun 24, 2006
  • Jun 24, 2006
agree with both post up top no shortcuts that i know of ......so you will have to do it the hard way
loosescrew79
313
  • Jun 24, 2006
I want to remove mine as well. Post pics when you get it done
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jun 24, 2006
  • Jun 24, 2006
Dont know any shortcuts, but Tomustang pity the foo that doesn't put electrical tape on the end of the springs.
TrueBlue03
372
Bay Area, CA
Jun 24, 2006
  • Jun 24, 2006
yup. not that easy. you basically just have to do it the same way as if you were swapping springs, but it does give the car that extra 1/4" - 1/2" drop that you're lookin for
lemme know if you want me to post a pic of before and after. im not in a whoring mood at the moment.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jun 24, 2006
  • Jun 24, 2006
Hell yea. Wrapped mine in electrical tape and i have had no extra noise at all
LI98GTStang
1,715
L.I., NY
Jun 24, 2006
  • Jun 24, 2006
OK, the hardway it is. Thanks for the replies and will definately use electrical tape as you guys recommend. Sounds reasonable to keep the springs from metal on metal contact - worked to diminish the noise transmitted through the Steeda tri-Ax, so it makes sense it should work here.
TrueBlue, no problem with the pics. I'll take some measurements and new pics when I'm done in a few days or so.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Jun 25, 2006
#10
  • Jun 25, 2006
  • #10
LI98GTStang said:
...worked to diminish the noise transmitted through the Steeda tri-Ax...
QUOTE]
I never thought of using electrical tape for that...nice little tip
Stang|ess
Oct 18, 2003
941
Hawaii
Jun 25, 2006
#11
  • Jun 25, 2006
  • #11
I didn't know about the electrical tape until 1 day after I took my isolators out .
N
For Sale FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Tuesday at 5:33 AM
nfilut43
N
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
