simple question. how do i remove the head studs from my old block to put onto my new block? a pipe wrench seems like an easy way but i'm not sure if it will mess the studs up in any way.
Pipe wrench???
First of all there should have been zero torque applied to the head studs when they were originally put into the block. All you do is bottom them out in the block and that is it. There is absolutely no need to place any torque on the stud itself. You should have also had some moly lube on the threads.
You should be able to easily back them out with the allen wrench that was provided with the head studs.
If you are using the stock factory head bolts, they are TTY (torque to yield) and are junk once they come off.
i dont think they have an allen wrench top. they are arp studs not factory bolts
