I believe you have to put a loop hose between the two ports. Fluid will want to move back and forth as you turn the steering wheel. Just draining all of the fluid probably isn't a good idea since the seals and stuff will dry out.
Is it a good idea? Go outside and try to try the steering wheel when the engine isn't running. You be the judge.
