  • SN95 4.6L Mustang Tech
Removing panels
  • Thread starter Thread starter mustang70
  • Start date Start date Jan 1, 2005
mustang70
2,445
San Diego
Jan 1, 2005
  • Jan 1, 2005
I need to remove a couple panels to get some work done in my car. One is the door panel. I popped the switch panel out and unscrewed the two screws behind there. I also popped the plug out of the front bottom, but it felt like something more then some clips were holding it in. What am I missing? The second one is the passenger side panel in the back. Does the bottom part of the back seat need to come out for it? If so, how does the back seat come out? TIA.
btolenti
277
Gilroy, CA
Jan 1, 2005
  • Jan 1, 2005
not sure about the rear panels, but it sounds like you got all the fasteners out. you just need to pull up on the door panel for it to come off. It does not come straight off.
xseler8
619
Montgomery County,Pa.
Jan 1, 2005
  • Jan 1, 2005
I did a thread "CDC lightbar installation" It will show pics of rear seat & panel removal
www.mustangweekly.com/2000/august/lightbar/lightbar1.asp
remove the seat belt from the floor(if you need to)
mustang70
2,445
San Diego
Jan 2, 2005
  • Jan 2, 2005
Is the door panel one or two pieces? It looks like it's two pieces from the inside. It still felt like it was connected around the front center though. I didn't want to pull to hard.
Wikkdgt
445
Cincinnati, OH
Jan 2, 2005
  • Jan 2, 2005
You have to pull out on the bottom as you are lifting up on the panel. It needs to be lifted up to clear the door lock. There also might be one more plastic clip on the front of the panel where the door hinges are.
H
Hoppy
329
L.A. CA
Jan 2, 2005
  • Jan 2, 2005
It's one piece.
Did you pull off your speaker cover too? That will make it a bit easier when you lift up and out. There are integral "L" shaped clips on the panel that require the up and out move. Also, there is a fastener at the lower front edge of the door (the "width" portion of the door), make sure that is removed too.
You can use the link in my signature to view pictures of my door panel removed....... to give you an idea what's doing behind the panel. I have additional pictures I can email if you need them. There is also a picture of the rear seat retention clip that needs to be depressed so you can remove the rear seat (there are two of them).
Hop
D
rear upper seat trim panel for 1995 ford mustang.
  • dustinbowman95gt
  • Aug 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
dustinbowman95gt
D
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
  • Mindseye007
  • Aug 16, 2026
Mindseye007
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
