removing pedal assembly
  • Thread starter Thread starter slow88stang
  • Start date Start date Mar 31, 2004
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
How hard is it too move the 3 pedals. im replacing my clutch quadrant with a new stock one(dont ask why...or tell me i should have gotten an aftermarket one) but it seems like the only way i can get the new ratcheting gear on is to take everything out...is this true?
there isnt enough room to get the ratchet gear over its pin or am i just stupid?
M
Matts89LX5.0
1,314
Long Island, NY
Mar 31, 2004
  • Mar 31, 2004
hmmm i don't think you have to remove the whole pedal assembly to replace a stock quadrant
slow88stang
144
St Albert AB
Mar 31, 2004
  • Mar 31, 2004
yea well i wouldnt think so either....there is not enough room to get the ratchet gear onto its pin...ive been working at this all day...easier to swap and engine and tranny than to replace a quadrant..dumbest thing ever
1qckFOX
139
  • Mar 31, 2004
You don't have to remove them, never heard of anyone doing that actualy. What do you need a ratchet for?
blk92stangg
583
Hawaii
Mar 31, 2004
  • Mar 31, 2004
The pedal removal is a big pain in the azz. You will need to remove all the trim under the steering wheel, disconnect all the harness plugs around the wheel, drop the wheel, and then remove the pedals. It took us the better part of a day and half to get the pedals in and out. I think going to an aftermarket quadrant will be easier, and better in the long run.
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
