  • SN95 4.6L Mustang Tech
removing rear package shelf
  • Thread starter Thread starter myg-
  • Start date Start date Jul 7, 2005
M
myg-
71
  • Jul 7, 2005
how do you remove the rear package shelf in a 96 mustng gt with mach 460 stereo? i cant figure this out!
if theres a tutorial type place with pics, diagram etc.. that would be great ;p
T
tjm73
2,418
Rush, NY
Jul 7, 2005
  • Jul 7, 2005
Not sure exactly what you're talking about. Do you have pics?
M
myg-
71
  • Jul 7, 2005
its the shelf in the trunk that holds the 5x7 component set and factory amps., that takes about 4 iches of trunk height away from u
T
tjm73
2,418
Rush, NY
Jul 7, 2005
  • Jul 7, 2005
Ohhhhhh, the subwoofer/speaker assembly. Perhaps you can find something at Crutchfield's website?
mustang70
2,445
San Diego
Jul 7, 2005
  • Jul 7, 2005
If you pull up the speaker grills and the carpet on the tray you'll see 4 (I think, it's been awhile) nuts that hold the box to the tray. Undo those nuts and the box will fall down, literally. As for the metal tray itself, it's welded in at the factory.
svtpower
257
Wisconsin
Jul 7, 2005
  • Jul 7, 2005
side piece first
You need to take out one of the coat hanger hooks from the back then pull out that triangle trim piece abit from infront of the seat belt spool. Then take flip down the seats, take out the bolts that hold on the trim piece and then pull it out. Then you can pull out the cardboard type piece with the speaker grills on it (you will have to bend it a tad) to expose the nuts that hold on the speaker box. Then go into the trunk, unplug all the wires from the box and support it with a box or a friend (it weighs about 25 pounds) and then undo the nuts and lower it down and pull it out.
Fun huh?
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
What is it Worth?!?!? May 18, 2026
nickyb
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
