  • SN95 4.6L Mustang Tech
removing stock studs header install
  • Thread starter Thread starter mineralgraygt
  • Start date Start date Mar 26, 2006
M
mineralgraygt
187
nj
Mar 26, 2006
  • Mar 26, 2006
hey guys im going to be installing my flowtech longtubes in a week or two and i bought stage 8 locking bolts to replace the stock studs. i was wondering if any of you guys have ran into any problems with the stock studs im afraid of breaking one. also how much is it for a new pair of header gaskets from ford?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Mar 26, 2006
  • Mar 26, 2006
Gaskets now come in a set of 4 (2 holes per unit). I paid $76 for 2 (1 side) at my local Ford dealership. I'd contact Randy over at MD for a very good price.
I wouldnt know how to remove the stock studs, mine stayed in the block
M
mineralgraygt
187
nj
Mar 26, 2006
  • Mar 26, 2006
see ive hurd guys reusing the stock studs and not having a problem i was thinking of doing that but i already got the stage 8s. im kinda worried about breaking a stud so i might just use the stockers.
blackfang
1,290
Richmond, Va
Mar 26, 2006
  • Mar 26, 2006
I got stage 8's but my studs cam out with zero issues. I used 4 of the flowtech studs as the stockers had clearance issues on 4 of them.
M
mineralgraygt
187
nj
Mar 26, 2006
  • Mar 26, 2006
you had clearance issues with the stock bolts doign what
blackfang
1,290
Richmond, Va
Mar 26, 2006
  • Mar 26, 2006
Stock studs. Some of studs were a little close on the flanges.
laxdman20
95
Va.
Mar 26, 2006
  • Mar 26, 2006
My stock studs came out with no problem. Sprayed em down with some liquid wrench 2-3 times before I took them out. I will warn you, I had 2 of the stage 8 bolts not fit with my BBK long tubes. I had to use the hardware that came with my l/t's for cylinder 7 and 8.
M
mineralgraygt
187
nj
Mar 26, 2006
  • Mar 26, 2006
oh damn that sucks how has it held up have them bolts came loose
blackfang
1,290
Richmond, Va
Mar 26, 2006
  • Mar 26, 2006
Nothing locktite can fix
laxdman20
95
Va.
Mar 27, 2006
#10
  • Mar 27, 2006
  • #10
I checked the bolts about every hundred miles for the first 500 miles. Mine never loosened at all. But I know when we did my buddies, his came loose around 200 miles after install. Just tighten them up and keep checking. Eventually they will stay.
M
mineralgraygt
187
nj
Mar 27, 2006
#11
  • Mar 27, 2006
  • #11
sweet thanks guys for you help
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
