removing strut questions..
  • Thread starter Thread starter latham83
  • Start date Start date Apr 20, 2007
latham83
496
  • Apr 20, 2007
i'm doing a strut install tommorow, and my chilton's book tell's me to remove the 3 nut's that hold the stock camber plate down?? do i have to do this? from what ppl were saying on here it seemed like all you had to remove was the big nut on top of the strut??
i don't wanna mess up my alignment, but i am going to get it aligned anyway afterwards just to be safe...
and is there something i need to mark down at the axle/bottom of the strut so i don't mess up alignment there??
4G-KDMP
935
CA
Apr 20, 2007
  • Apr 20, 2007
no reason to remove the 3 nuts on the cc plate.
just remove the large nut that holds the strut in place.
stang&2Birds
2,091
New England. :-) CT/MA
Apr 20, 2007
  • Apr 20, 2007
I don't know what good taking off the bolts for the camber plate would do.
Regardless, you must remove the top nut. To do that, you'll need an impact wrench. The electric impact wrenches work fine (Wal-mart ~$60, Home-Depot ~$200).
To remove the top nut, do it with the car on the ground, or a jack under the control arm. That puts some pressure on the strut top. Also, you'll need to do the same to put the nut back on.
HISSIN50
34
129
Apr 20, 2007
  • Apr 20, 2007
Another popular manual says to do the same thing as your Chiltons. I have NO idea why they say to do that. Perhaps it's to create extra work and ensure that you get an alignment.
As S&2B's said, just undo the strut rod nut itself. If you dont have impact tools, I have a hand-tool variant method that works well for me.
Good luck.
stang&2Birds
2,091
Apr 20, 2007
  • Apr 20, 2007
Good luck.
I looked, and looked, and looked. I couldn't find the tool. I tried a big screwdriver and open-end wrench. That didn't work for me.
Where did you find the tool? Or, did you make your own? I'm not crazy about using an impact wrench and spinning the top of the strut inside the body.
HISSIN50
34
129
Apr 20, 2007
  • Apr 20, 2007
I've had very good luck using a prybar (like this) in the strut slot. Before coughing about the cost, I use a cheapo pry bar but that was the first decent representation I found. Mine came from HF IIRC.
I hold the prybar horizontal in the strut slot (not like a screwdriver - we have no leverage that way). With the prybar parallel with the ground, I can hold the strut rod from spinning while using a wrench on the strut nut. I loosen and tighten them up that way because, like you, I don't like 'blapping' those nuts on and off. Sometimes blapping one off is unavoidable but I've never had to blap a nut back on.
Oh, I'm too poor for most specialized tools, so anytime I post about some method I use, rest assured I'm not doing anything the way you're supposed to.
stang&2Birds
2,091
Apr 20, 2007
  • Apr 20, 2007
Cool idea! Yea, holding a screwdriver (or what ever) vertical means no leverage.
I'm starting spring change #N in this weekend. Don't ask. I'll try that method to get the nuts off/on. I'm also concerned about the top seal on the strut getting worn/damaged by doing the nut blapping off/on.
Thanks again!
RYC CUKR
1,437
Orlando
Apr 20, 2007
  • Apr 20, 2007
I did the same thing that Hissin did to remove the strut nut on my 93 when I put my 70/30s on. Worked like a champ.
latham83
496
  • Apr 21, 2007
yea i like the sound of that method too..only thing is, you cant get a torque wrench on the top of that nut then.. i think they want like 50-60 ft/lbs... im not good with guessing the torque blind..
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 8:51 AM
Rdub6
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
