removing t-5
  • Thread starter Thread starter krafty
  • Start date Start date Jun 26, 2005
K
krafty
59
North Dakota
Jun 26, 2005
  • Jun 26, 2005
Is it possible to remove the trans with the car on jack stands or do you need a hoist. I am just wondering what kind of clearance you need to pull the tranny.
J
JerryDaugherty
309
Near Dallas
Jun 26, 2005
  • Jun 26, 2005
jacks will do just fine. Jack the corvers on stands and then lower the trans with the jak. A+
mysticfire5OH
72
Fort Wayne, IN
Jun 26, 2005
  • Jun 26, 2005
I just pulled mine yesterday with jack stands. Its doable. Much easier with a hoist though. Tip: don't support the rearend let it hang and put the jackstands where the lower control arms connect to the body. this will allow you to take out the DS bolts much easier because of the angle. good luck
SIRX
  • Jun 26, 2005
I put jack stands under all four corners and that works really good. I have a good pair that lift about 2 feet and a cheap 15 dollar pair that lift about 18 inches. put the cheapies under the front and the other pair in the back. I used to put ramps under the front tires and the cheap stands under the axle and that worked also.
74courier
158
vancouver wa
Jun 27, 2005
  • Jun 27, 2005
i just put ramps under the front and took the trans out with my arms lol it only weighs like 50 pounds
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 27, 2005
  • Jun 27, 2005
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
