Have to drop the tank. Unbolt the tank straps. The neck comes out of the side rubber grommet. Before it comes all the way down the fuel lines have to be disconnected. Finally with the tank down you can remove the pump. Hammer and flat head screw drive to the tank ring. Now you can remove the pump. VERY IMPORTANT-remember in your mind how the pump snaked out. It must be put back the same way. The strainer must sit in the sump or you will be doing it again. Tools that are needed are a ratchet, 1/2 socket, hammer screw driver and fuel line disconnect tool. Make sure the tank is empty and you have another person to help bring the tank down.
