  • 2005 - 2009 Specific Tech
Removing the Gauge Cluster
  • Thread starter Thread starter whyask
  • Start date Start date Nov 20, 2008
whyask
735
Sacramento
Nov 20, 2008
  • Nov 20, 2008
I just ordered some new LEDs for the Cluster but I cant figure out how to remove the setup ...anyone have a write up!! Im at work and very bored and need a project this week !
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Nov 20, 2008
  • Nov 20, 2008
check the ultimate sticky, and look for anthony's cluster swap. i believe he tells you how to pull it out. i have had mine out, but dont recall the exact steps to do it.
whyask
735
Sacramento
Nov 20, 2008
  • Nov 20, 2008
thanks Bigcat! I didnt even think about the sticky..damn noob move !
whyask
735
Sacramento
Nov 20, 2008
  • Nov 20, 2008
well i searched the sticky and nothing ... the sticky thread we have is just for the stereo area.....SO im back to square one !
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Nov 20, 2008
  • Nov 20, 2008
Removal and Installation
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
Depower the supplemental restraint system (SRS).
Remove the floor console.
Remove the 2 scuff plates.
Remove the 2 A-pillar lower trim panels.
NOTE: On coupe, install the front locating hook, then snap the A-pillar trim panel in place working rearward. Remove the 2 A-pillar trim panels.
Remove the instrument cluster.
CAUTION: Do not allow the steering column to rotate while the steering column shaft is disconnected or damage to the clockspring can result. If there is evidence that the steering column shaft has rotated, the clockspring must be removed and recentered. Secure the steering wheel, remove and discard the bolt, and separate the steering column shaft from the steering column.
To install, tighten to 25 Nm (18 lb-ft) .
On the LH side disconnect the instrument panel bulkhead electrical connector and remove the instrument panel support bolt.
To install, tighten to 20 Nm (15 lb-ft) .
On the RH side disconnect antenna in-line connector and the 4 instrument panel harness electrical connectors.
Remove the 2 instrument panel center support screws.
Remove the 3 instrument panel center support bolts.
Through the instrument cluster opening, loosen the instrument panel cowl top bracket nut.
Tighten to 9 Nm (80 lb-in) .
Remove the 2 instrument panel lower support bolts.
To install, tighten to 9 Nm (80 lb-in) .
Remove the 2 instrument panel end panels.
Remove the 4 instrument panel upper support bolts.
NOTE: Two technicians are necessary to carry out this step. Remove the instrument panel.
To install, reverse the removal procedure.
Hope that helps.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Nov 20, 2008
  • Nov 20, 2008
Here is another one.
NOTE: Prior to removal of the instrument cluster, it is necessary to upload the instrument cluster configuration information to the diagnostic tool. Depower the supplemental restraint system (SRS).
NOTE: The instrument cluster finish panel is held in place with retaining clips that are attached to the bezel. Remove the instrument cluster finish panel.
Remove the 4 screws and the instrument cluster.
Disconnect the electrical connector.
Download the instrument cluster configuration information from the diagnostic tool into the new instrument cluster.
C
CPman
129
  • Nov 21, 2008
If you have tilt steering, tilt the wheel all the way down and then with a quick jerk just pull the cluster bezel out. From there the cluster unbolts, unplugs and slides out. This whole process only takes about 5 minutes.
whyask
735
Sacramento
Nov 21, 2008
  • Nov 21, 2008
And once again the forum FCKN ROCKS !!! THANK GUYS !
GOLDENPONY
1,503
LOVELAND, OHIO
Nov 22, 2008
  • Nov 22, 2008
Cluster
I removed my '06 cluster to install white face gauges. It was very easy and I didn't have to upload any info, I just installed the white faces and re-installed. No sweat.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
J
For Sale 1984-1986 GT GAUGE CLUSTER TRIM PANEL
  • jiminecricket
  • Apr 27, 2026
  • Interior Exterior Parts
Interior Exterior Parts Apr 27, 2026
jiminecricket
J
