Removal and Installation
CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
Depower the supplemental restraint system (SRS).
Remove the floor console.
Remove the 2 scuff plates.
Remove the 2 A-pillar lower trim panels.
NOTE: On coupe, install the front locating hook, then snap the A-pillar trim panel in place working rearward. Remove the 2 A-pillar trim panels.
Remove the instrument cluster.
CAUTION: Do not allow the steering column to rotate while the steering column shaft is disconnected or damage to the clockspring can result. If there is evidence that the steering column shaft has rotated, the clockspring must be removed and recentered. Secure the steering wheel, remove and discard the bolt, and separate the steering column shaft from the steering column.
To install, tighten to 25 Nm (18 lb-ft) .
On the LH side disconnect the instrument panel bulkhead electrical connector and remove the instrument panel support bolt.
To install, tighten to 20 Nm (15 lb-ft) .
On the RH side disconnect antenna in-line connector and the 4 instrument panel harness electrical connectors.
Remove the 2 instrument panel center support screws.
Remove the 3 instrument panel center support bolts.
Through the instrument cluster opening, loosen the instrument panel cowl top bracket nut.
Tighten to 9 Nm (80 lb-in) .
Remove the 2 instrument panel lower support bolts.
To install, tighten to 9 Nm (80 lb-in) .
Remove the 2 instrument panel end panels.
Remove the 4 instrument panel upper support bolts.
NOTE: Two technicians are necessary to carry out this step. Remove the instrument panel.
To install, reverse the removal procedure.
Hope that helps.
