For the rear inside panels you have to remove the rear seat, top & bottom. The bottom has a latch you have to push in app 10" from the the edge. Push that in & pull it out. The upper seat back has 2 10mm bolts, then it comes up & out. Once the seats are out, then remove the door seal piece by pulling it up. There is a plastic push thing on the inside of the panel that has to come out.
