Removing Wheel Spacers??
02FastblackGT
64
Tucson, AZ
Hey guys,
So when I bought my GT, the guy already had the 1 1/4" wheel spacers on there, which look great for the stock 8" wide wheel. I know I want to get new wheels, and would prefer the 10.5" wide for the rears. Of course, I cannot get the 10.5" wide w/ the wheel spacers on, because they would stick out too far, so I wanted to see how hard it is to remove the wheel spacers?? I know that I have the kind that bolt on...do they usually just bolt onto the stock wheel studs?? If so, then I should only have to remove the nuts that hold the spacers on, and then they should just slide off??:shrug: I should now be able to install a new wheel of any desired width..(assuming that the stock studs were not messed with). Does this sound about right?? Thanks!!:nice:
fluffyrunnells said:
yes....just unbolt, and your stock studs will/should be fine....
Agreed, although when I took mine off after about a year I had to "encourage" them with a hammer. The bolts came off okay, but the aluminum spacers decided they liked the steel rotors. If you do have this problem, just a couple light/medium whacks on the sides of the spacers should get 'em...:nice:
rotors..???
02FastblackGT said:
Hey guys,
They just unbolt and come right off. If there is corrosion and rust build up the spacer will seem stuck to the rotor. If they are spray some WD40 to loosen it up first then give a shot with a hammer.
Would you be interested in selling them?
