I just ordered the tool to remove the windshield-molding that goes around the windshield of my foxbody Mustang and an extra set of clips incase some of the clips get damaged during removal.
My question to the forum is for those who have removed their moldings once before.
How do I use that tool to remove the molding from the windshield?
Does the tool go between the glass and the molding or between the roof and the molding? Do I "lift-up" with the tool, or do I pry it on the molding and use the surface a leverage?????? I don't want to crack the glass or GOD FORBID, damage the molding itself as it's practically irreplaceable
Also, I noticed that the top molding is kind of joined/locked into to the moldings running down either sides of the windshield on the A-pillars. Do I basically work my way around the windshield starting at the base of the A-pillar, up the side of the A-pillar and then work up and over along the molding on the top of the windshield?
Or can I just remove the top molding strip on its' own??????????? I really need to only get after the top molding, passenger side of the windshield.
Please help as I'm looking to do this on the up coming weekend.
Thanks in advance.
Thanks in advance.
This is probably not the reply your looking for, but..... Take it to a windshield place, pay a little and have them remove and replace the moldings. At least this way they shouldn't get broke and all will be good. There is nothing wrong with doing it yourself, but sometimes its worth a little to have the professional do it so as to not damage anything else. Good luck whatever you decide and with your project
