Repairing a torque box...
ratio411
3,870
73
109
Pensacola FL
The passenger side box on my 87 GT looks like it was drug over a stump or something...
It is crushed back towards the rear.
If I was to put the car on jack stands and cut the box out to replace it, where should I put the jack stands so as not to bend the car while the box is taken apart? I don't want the chassis to sag. I had this happen on another vehicle, and the doors never closed right again.
Im assuminf lowers correct? If so why not tack a support rod like a subframe connector that is sturdybut put it on the rails somewhere thatll be outta your way
as long as your not cutting out the frame rail your fine, the lower torque box can be removed no problem without worrying about the car "sagging"
