- Feb 11, 2009
- 245
- 2
- 19
Hi there
With the original Alternator on my 87 Mustang the car use to show that it charged right about where it should of been untill i changed the Pullies to underdrive and then the V meter on my dash started to show like 10 - 11 and would drop lower when running lights etc. even when i put the power windows down. If i accelerate the gauge would show like 13V or more but on stoping in trafic (coming to Idle point) the gauge would drop once again.
I changed the Alternator to a sigle wire alternator (wired up right) and the problem presist. I even went as far as to change the Serpt Belt thinking it could of been sliping. The problem is still there. When i tested the Batery with the Multi Meter the car was at idle 700 / 750 RPMS and the meter read 11.9 / 12.0 V. I also put the + lead on the one wire lead on the Alternator and the - to a body ground and came up with the same results (11.9 / 12V).
Whats left to do? its driving me crazy. I also run a 6AL MSD and dont want to run to low on Volts with that.
Help me Please??????????????
