replaced ignition switch... still getting nothing.
90lxfoxbody
264
ok, by this point i am genuinely pissed. i replaced the ignition switch and still nothing happens when i turn the key. i replaced the starter solenoid, checked all the fuses, fusebox, fusibles, wiring etc etc. what the hell could cause this. i have power from the battery, i can jump the starter solenoid and make the engine try to turn. could it be the two little plastic fuse box things under the dash? would the neutral safety switch going out keep the gauges from registering when i turn on the switch? i don't think it would. i think it would just prevent the car from cranking. i need my car running bad - my job is depending on it. where is the computer in a 90 lx 5.0 and how do i check it?
will have to go buy a test light - without a car that will prove a long damned walk. i am hoping it is a fusible. i just got back from tearing the interior out in a chase for burned wires and anything obvious. i can't see anything.
Back to basics...
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
ok, i have read over the haynes manual's wiring diagrams which pretty much mirror what these show. without a meter i am pretty much stalled cold. i am faced with a long walk to hd to pick up as meter or throw in the towel and have it towed so a mechanic can start wrenching on it.
Check the cluster of wires on the steering column that goto the ignition switch connector. I had one of those wires melt off and i didnt see it until AFTER replacing my ignition switch and starter solenoid. It melted almost right inside the connector. Check real good for a burned wire in there, they are sometimes hard to spot.
Do you have supplies to solder together a test light?
WHen you get a chance, you can grab a DMM from Harbor Freight for 3-5 bucks on sale, and their test lights are often 1 buck.
Do your gauges still not register if you turn the key on? Interior lights work?
Good luck with it.
gauges do not register when i turn the key on. the cd player will eject the cd but will not play on the accessorry position or the on position. i disassembled the dash looking for burned/frayed wires and found nothing. this is really baffling. i am going to have to bite the bullet and pay to have it towed, then pay a mechanic $65 an hour. i hate doing that..........
Before tossing the towel, I would call up a buddy and have him/her bring you a test light or better yet, a DMM. It really sounds like between checking wires at the solenoid and ignition switch, you should find the issue (this is a huge issue, which should be easy to find).
When you put the switch back in, was the ignition lock turned to off?
Anyhow, I would check values at the ignition wires and go backwards (toward the solenoid) from there.
FWIW, a fusible link that has blown can feel kind of mooshy/soggy. A test light or meter can test each side of them real quick.
We just wanna see you get it fixed yourself, for the money savings and satisfaction.
Good luck.
trust me hissin - i am most grateful for all the help. i am going to give it one more look before i call a mechanic. i have been hoping it is something simple like thc mentioned - i just have to find it.
A meter would really help get the troubleshooting in a major way. Also do a quick check on other electrical subsystems and see what is working. Find out what all that is powered is working like lights, windows, locks, etc. Every little bit wil help.
