I replaced the intake and valve cover gaskets and now the car won't start. First time I turned it over it started but idled terrible. No response when you press the gas. My thermo housing was leaking so I had to pop that back off and now it won't run at all. I removed the distributor and THOUGHT I had it back in correctly but I'm thinking this is the problem.
I pulled the #1 plug, turned the crank to line up the 0 with the timing pointer and #1 plug wire on the dizzy cap when on the compression stroke. When I try to start it it just backfires out of the exhaust. What now? I need this thing to drive to work tomorrow.
