Engine Replacement Oil Pans
Mustang5L5
Mod Dude
Feb 18, 2001
43,320
18,044
224
Massachusetts
I'd like to swap out my oil pan as I've always had issues with the rear drain plug leaking no matter what I try. Also, because I need a new dip stick, I was thinking the M-6675-A50 pan kit was a good idea.
https://www.summitracing.com/parts/FMS-M-6675-A50/
However, no bung for the low oil sensor. For this reason I'm kinda heistant to buy it even though I'd just simply pull the dip stick to check oil like I should be doing anyway rather than rely on the bulb.
Looking around, all other pans seem like cheap Chinese junk with bad reviews. I also don't want to spend $400 on a high end pan.
As I read around and search, I think i'll just leave the sensor off. One less potential leak spot. I'll just pull the dipstick like I should.
Now the debate between this kit...or a 7 qt pan.
