replacement overflow tank?
  • Thread starter Thread starter jmd2914
  • Start date Start date Jun 21, 2007
J
jmd2914
937
Napa, California
Jun 21, 2007
  • Jun 21, 2007
i have a sable electric fan in my car. my stock radiator overflow tank got chewed up in my belt. ( long story) anyway im lookin for a replacement. where can i get one? preferably aftermarket that will fit with the stock radiator.
thanks
Joel
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jun 21, 2007
  • Jun 21, 2007
Junkyard, or 50resto.com for an OEM tank.
Otherwise, you can just make one out of a PVC/ABS sewer pipe, some caps, and some fittings. I think it was HISSIN50 that had one ... or was it JRichker? Or ... oh, hell, my memory's shot. Someone did it, I dunno who, but it was pretty nifty...
HISSIN50
34
129
Jun 22, 2007
  • Jun 22, 2007
JRichker had the nice (Homemade PVC tank) idea and I bastardized it to work on a 94-95 (tighter clearance specs under the hood. Very much the same idea as Jrichker's though).
DW's ideas are where I'd start too. If you hit the J/Y, try to ensure the thing aint leaky.
If you have green stuff oozing out of your pockets, you could go for an alum Canton. They're beautiful.
And some use a catch can (alum or plastic), or a reservoir from another car.
Good luck.
J
jmd2914
937
Napa, California
Jun 22, 2007
  • Jun 22, 2007
what other cars could i pull one off of?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 22, 2007
  • Jun 22, 2007
My DYI setup made from Home Depot PVC pipe – cheap except for the aluminum for the mount bracket.
Advance Discount Auto Parts has a cheap (less than $8) plastic kit, but mounting space may be an issue.
See http://www.partsamerica.com/ProductListSimple.aspx?Category=3052
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Jun 22, 2007
  • Jun 22, 2007
I've been using the above pictured Autozone catch can. It works, although it looks tacky, and it barely leaves any room between itself and the A/C pulley/belt.
Juiced88Coupe
367
Austin, Texas
Jun 22, 2007
  • Jun 22, 2007
This is what I used....
monte87
876
18
49
new york
Jun 22, 2007
  • Jun 22, 2007
Dude-
Mt Laurel mustangs in PA has the stocker for $28..... Just both one, a few months ago.
Later Ant
J
jmd2914
937
Napa, California
Jun 22, 2007
  • Jun 22, 2007
how much was the moroso one?
Juiced88Coupe
367
Austin, Texas
Jun 22, 2007
#10
  • Jun 22, 2007
  • #10
the tank was $28.00, and the mount was $7.00. I've tried just about every overflow that would fit, and this setup i'm most pleased with. With everything mounted into the fender most people dont think i'm running a tank at all.... I did swap the fittings on the tank and moved the brass 90 to the bottom and the fuel valve to the top for the vent. I got everything from summitracing.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
P
Mishimoto Radiator leak 1987 Foxbody 5.0
  • PHoffman
  • Jan 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 18, 2025
Trogdor
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
