  • 1994 - 1995 Specific Tech
Replacement timing chain - Single or Double?
  • Thread starter Thread starter StangRider1
  • Start date Start date Sep 28, 2005
1 of 2 Next Last
StangRider1
45
Vancouver, Washington
Sep 28, 2005
  • Sep 28, 2005
Folks,
I have to replace the timing chain cover engine seal as it's leaking coolant, and since the timing chain is original and now has 120,000+ miles on it, I figure it's due for a replacement before it fails. So, my question to all of you experts out there is - Should I get a single-row replacement or a double-row? Which one and why? Any help is always appreciated!
Kerry
bjl95mustang
1,495
Austin,TX
Sep 28, 2005
  • Sep 28, 2005
Get a double. I'm not 100% sure but i think the stock one is a double too.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Sep 29, 2005
  • Sep 29, 2005
my vote is for double too
krahkin
183
Acworth GA
Sep 29, 2005
  • Sep 29, 2005
I run the FRPP Double roller, its a nice piece. Also make sure to get the heavy duty thrust plate to go along with it.
4Jenna
4,326
AZ
Sep 29, 2005
  • Sep 29, 2005
Double roller hands down, FMS is a nice piece
Killercanary
The car that set the bar.
Altoona, PA
Sep 29, 2005
  • Sep 29, 2005
Get a double roller. I run the FMS unit in mine, but the roll master timing chain setup is a VERY nice piece too. I will have one on my next setup.
DFG 5OH
1,341
Louisville, KY
Sep 29, 2005
  • Sep 29, 2005
anyone have the FMS part number? And the part number for the heavy duty thrust plate?
CManT1914
3,172
Killeen, Texas
Sep 29, 2005
  • Sep 29, 2005
Matt, this is the part number for the FRPP one I got from summit.
FMS-M-6268-B302
It's $69.95
To the original poster, go with a double-roller (like it hasn't already been said, lol).
StangRider1
45
Sep 29, 2005
  • Sep 29, 2005
Good info guys, Thanks.
Double roller for sure.
Paul, any ideas on where to go to get the RollMaster at the lowest price? B/C, OMG are those things pricey!
Thanks again, and keep it coming fellas!
Kerry
W
WhiteSN95
142
#10
  • Sep 29, 2005
  • #10
PM me if you are interested as I have a rollmaster timing chain I am getting rid of.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 29, 2005
#11
  • Sep 29, 2005
  • #11
Kerry
Aother thumbs up for the Roll Master.
Very nice and top quality.
Its been almost three years ago since I got mine but I wanna say it was about 25% higher than the FRPP unit. Maybe they went up, I dunno.
Ed Curtis told me they had seen several of the FRPP units explode at the track.
I got some pics of it on my site if you have never seen one.
Grady
krahkin
183
Acworth GA
Sep 29, 2005
#12
  • Sep 29, 2005
  • #12
Here is the thrust plate number: FMS-M-6269-A351 .
CManT1914
3,172
Killeen, Texas
Sep 29, 2005
#13
  • Sep 29, 2005
  • #13
Grady
What exactly would happen if a timing chain blew off? I'm assuming you'd bend every valve huh? That would suck!
nazstang
204
Rhode Island
Sep 29, 2005
#14
  • Sep 29, 2005
  • #14
happened to me in my nissan, bent all but 2 valves, and that was because i turned it off right away and didn't try to crank it over. it also notched a few slits to my pistons. not fun, $$
anyways, question, i might change mine soon too, i'll go with the fms, is the thrust plate a must? how tough is it to do? thanks
StangRider1
45
Sep 29, 2005
#15
  • Sep 29, 2005
  • #15
Naz, yes the thrust plate is a must, if not things don't line up right, and eventually you can end up with LARGE chunks of metal in your oil pan, definitely not good ! As for how tough, not very, just time consuming pulling the front of the engine bay apart.
Thanks again for the part numbers guys.
Grady, nice site, excellent idle clip, verry sweeet!
Keep 'em comin' fellas!
Kerry
CManT1914
3,172
Killeen, Texas
Sep 29, 2005
#16
  • Sep 29, 2005
  • #16
I disagree, up until now, I've never even heard of having to change the thrust plate. I know plenty of guys who didn't (myself included) and have had no problems. Just MHO.
StangRider1
45
Sep 29, 2005
#17
  • Sep 29, 2005
  • #17
Chris,
Not arguing, just stating what I've personally seen in the past. Buddy of mine years ago had a Chevy 350, put a new double-roller timing chain in it, forgot the thrust plate, and within 2 weeks had destroyed the chain, crank sprocket, and chain cover, most of the pieces ended up in his oil pan. I think you may have been lucky.
Kerry
blk9450
1,507
your moms bed
Sep 29, 2005
#18
  • Sep 29, 2005
  • #18
maybe its a chebby problem, i have never had or seen or heard of anything like that
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 29, 2005
#19
  • Sep 29, 2005
  • #19
I kinda also think that is a chevy thing
Seen em talk about the "button" behind the cam plate for years.
Grady
a50sn95
368
Elk Grove, CA
Sep 29, 2005
#20
  • Sep 29, 2005
  • #20
I guarantee you that of all the cam swaps done on 5.0's the MAJORITY (I'd say 90%) don't replace the cast iron thrust plate with the steel plate. Why? What is being changed that will cause the cam to push against the thrust plate harder than stock? Nothing (except maybe a HV oil pump, but I'd say that it would be marginal). Why is it an issue in Chevy's? They don't have one to start with (Pre-roller cam engines). There is a "button" that goes in the front of the cam that pushes against the stamped steel timing cover that keeps the cam from moving forward. Frequently, they are left out during a rebuild, and failure is the result. Hence, there is a big opportunity for the AFTERMARKET, and Chevy even added the thrust plate in when they went roller.
Personally, I think it's an uneeded expense (50.00 @ summit)
Also, I think this is a good example of why not to use "my buddy with a camaro did it, so..."
Dennis
1 of 2 Next Last
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
