  • 1994 - 1995 Specific Tech
Replacing 95 AODE
  • Thread starter Thread starter tonej5
  • Start date Start date Mar 28, 2009
T
tonej5
  • Mar 28, 2009
Hi guys new to the forums here. I have a 95 gt and my AODE tranny has bit the dust. I'm wondering what my options are as far as replacing it. Do I need another one from a 95 5.0 or would something else work?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Mar 28, 2009
  • Mar 28, 2009
Depends on how much work you want to do. A 94-95 GT is a stock replacement. You can use a 4R70W from a 96-98 I believe, but you'll have to convert the sensors over. You can also go to several websites and have them build you a stronger tranny.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 28, 2009
  • Mar 28, 2009
If you use the 4R70W, it has to come from a V6, so the bellhousing bolt pattern matches the block (the 3.8 and 5.0 are both Windsor engines).
toyman
1,944
54
79
Vernon BC
Mar 28, 2009
  • Mar 28, 2009
However, you can install the 4R70W internals into the AODE case, or so I'm told.
KamiKaziDK
555
Mesa, Az
Mar 28, 2009
  • Mar 28, 2009
Just get another AODE from a 94/95 mustang.....or if you have the cash, buy an aftermarket one, you'll be happy you did later. I'm on my 3rd aode because I have only ever had the money to buy used ones when they go out on me. If I'd bought a PA aode in the first place I'm sure I'd still have it.
99FiveOh
2,051
20
99
J-Ville, FL
Mar 28, 2009
  • Mar 28, 2009
I can't see where you're from, but I'll have mine available soon. Recently rebuilt with some valve body work and springs done. It shifts really nice and is like brand new now.
I'm doing a 5 speed swap so I won't need it. I live in the Jacksonville FL area.
Dino Dino Bambino
1,672
89
79
Cyprus
Mar 29, 2009
  • Mar 29, 2009
This is a good opportunity to upgrade so you can either:
1. Rebuild your existing tranny with the internals from a '98+ 4R70W. This has the stronger mechanical diode intermediate one way clutch.
2. Swap in a 4R70W from a '98+ V6 model, reuse your old valve body and sensors, and add a shift kit.
The 4R70W has other advantages over the AODE such as higher ratio 1st/2nd gears for faster take off, stronger gearsets, and a stronger output shaft. If you get a '98+ model you also get the mechanical diode so the tranny will be virtually bulletproof.
Whatever you do, I strongly recommend adding a heavy duty external tranny fluid cooler to prolong the life of the tranny.
KamiKaziDK
555
Mesa, Az
Mar 29, 2009
  • Mar 29, 2009
T
tonej5
  • Apr 4, 2009
thanks for the replies guys. I think the 4R70W idea sound like the way to go
D
DavidNC
119
#10
  • Apr 24, 2009
  • #10
If you can pick up my old 95 auto tranny from Burlington, NC, you can have it. It worked great when removed several years ago with 80K miles on it.
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
