Replacing bad convertible top hydraulic cylinder.
don ruggles
52
05 vert! Found out the passenger side hydraulic cylinder is sluggish. The other side works great. I think I'll just replace the one. Any thoughts on this? I'm a fair mechanic, but never worked on a top mechanism before.
I tried bleeding it out after filling and refilling, but the cylinder seems bad.
  • Sponsors(?)
don ruggles
52
Ordered the USA made one for 119 off Ebay. 5 yr. warranty. Won't get it til at least Aug. 6th.
Thread starter Similar threads Forum Replies Date
2 Timing chain replace gone bad please help 1996 - 2004 SN95 Mustang -General/Talk- 1
M Transmission Bad Need To Replace Fox 5.0 Mustang Tech 8
Ivan Cheranev Engine Bad Noise. After Hydraulic Lifter Replacement 1994 - 1995 Specific Tech 32
393strokervert can I swap in a c&l mass air to replace my bad Pro-m meter & use the same chip? Fox 5.0 Mustang Tech 13
spirockp Bumper replacements, the good, the bad... 1965 - 1973 Classic Mustangs -General/Talk- 2
M Simple Alternator Replacement Turned Bad SN95 4.6L Mustang Tech 10
MustangLX-5.0 Got a bad dash dimmer switch? Try this fix before you replace. It works. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
L Water pump dead / how bad to replace? 1994 - 1995 Specific Tech 19
bloopbloob PCV valve - how often to replace, how can you tell if bad? Fox 5.0 Mustang Tech 4
A 2 lifters are bad...which stock replacements do I need to order? 1996 - 2004 SN95 Mustang -General/Talk- 1
S Replacing my entire interior.....bad idea? Classic Mustang Specific Tech 5
8 Think my clutch cable is bad...how to replace? Fox 5.0 Mustang Tech 20
R Clutch replaced now everything vibrates really bad!!!! Fox 5.0 Mustang Tech 8
T 02 sensor bad, does it HAVE to be replaced right away? SN95 4.6L Mustang Tech 2
jaidedeye replacing bad cats on bassani x pipe Fox 5.0 Mustang Tech 10
W Help! Idle is surging badly....tried replacing everything Fox 5.0 Mustang Tech 10
FastGT94 Bad Vibration from Rear End after replacing pinon seal Fox 5.0 Mustang Tech 10
97GTSTANG Bassani X with cats bad, need replacement...Any Suggestions? SN95 4.6L Mustang Tech 10
FrdMustangCpe Still Havent Rebalanced/Replaced driveshaft (vibration) anything bad happening? Fox 5.0 Mustang Tech 16
N clutch replaced, bad vibrations SN95 V6 Mustang Tech 10
K Sun visor replacement 1998 convertible 1996 - 2004 SN95 Mustang -General/Talk- 0
D Drivetrain Replaced tranny but not shifting... 1994 - 1995 Specific Tech 3
5 Powersteering Pump replacement gone wrong Fox 5.0 Mustang Tech 15
D V6 Abs module replacement 1996 - 2004 SN95 Mustang -General/Talk- 0
T Engine EGR spacer rear hose replacement. '93 5.0 Fox 5.0 Mustang Tech 9
Gs87GT Suspension Replaced front lower control arms and springs....suspension won't compress? Fox 5.0 Mustang Tech 9
M Replaced abs module, working good now 1996 - 2004 SN95 Mustang -General/Talk- 0
N Replacement Options for 2001 Mustang SVT Tail Lights-Damaged in Hail Storm SN95 4.6L Mustang Tech 0
351crownvic Engine 95 5.0 replacing 93 5.0 questions Fox 5.0 Mustang Tech 8
R Best clutch cable replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
J Idle issue still!! Replaced several parts.. looking for more ideas!! Fox 5.0 Mustang Tech 12
S Replacing stock tires and wheels on my 04 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 0
C Convertible windshield replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Red50Fox Fox steering shaft (rag joint replacement) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
R Fuel 87 GT - FUEL LINES - REPLACEMENT / ROUTES?? Fox 5.0 Mustang Tech 4
J Hazard lights flashing before/after SJB replacement 2005 - 2014 Specific V6 Tech 0
C 87 Convertible pump and cylinder replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
LILCBRA Oil pan gasket change OR starter replacement in a 302 II 1974 - 1978 Mustang II Talk & Tech 11
J Engine replacement advice 4.6 1996 - 2004 SN95 Mustang -General/Talk- 3
0 Replace o2 sensors or not? SN95 4.6L Mustang Tech 5
realtex Electrical AC clutch cycle switch replace 1994 - 1995 Specific Tech 1
calmlikeabomb 96 Cobra power steering issue... what is this line? can I replace it? SVT Tech Forum 2
1989FoxFan Interior and Upholstery [Solved!] Should I replace the pads and cables for my top 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
B Paint and Body '86 Four Eye Headlight Fiberglass Assembly - Repair or Replace? Fox 5.0 Mustang Tech 4
90sickfox DUSTY'S New Start After Intake Replacement Digital Self-tuning Forum 3
T Exhaust Replacing cats with O/R x pipe and need a tuner Fox 5.0 Mustang Tech 6
pats91 Paint and Body Floor Pan Replacement - Can a SN95/New Edge floorpan be used in a Fox Fox 5.0 Mustang Tech 4
M Engine Knocking nosie after replaced upper intake manifold SN95 4.6L Mustang Tech 4
Foxslider Foxbody junkyard direct replacement axles 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
A Transmission Replacement Question SN95 V6 Mustang Tech 1
