Replacing rods
  • Thread starter Thread starter Saleen8786
  • Start date Start date Feb 12, 2004
Saleen8786
209
Marlton, NJ
Feb 12, 2004
  • Feb 12, 2004
Hi im new here and i just baught a 1967 coupe for $1200 no rust nothing just that the engine didnt run well its knocking. What could the problem be does it need new rods or bearings or something please help me out and i would like to change it to an 8cylinder by putting a 1990 Gt 5.O motor what would i need to do and how much would it cost.......
G
GaPonyFarm
663
Columbus, GA
Feb 12, 2004
  • Feb 12, 2004
If its knocking, the only way to really find out is to tear it down and take a look.
It appears that you may want to swap from a 6 cyl to a v8? If that is correct, you are looking at upgrading the engine, front suspension, tranny (at least bellhousing), probably front brakes, exhaust system, and rearend work (if you also want a 5-lug system all around). The costs depend on where you're getting the new parts, level of conversion, and who's doing the work. You can easily spend $10k, or get by on $3k.
I know this isn't much help, but it should help you focus on what you want to do.
Edbert
3,548
32
109
Austin TX
Feb 12, 2004
  • Feb 12, 2004
The sounds could be many things. Are they coming from the valve covers, the intake manifold, or the oil pan? We should start there
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 12, 2004
  • Feb 12, 2004
Very likely, knocking rods are also accompanied by crankshaft damage. In which case, replacing the rods alone will soon find opportunity "knocking" again reminding you that you should have had the crankshaft repaired/replaced also.
Sorry, I have lots of experience that supports my view.
zookeeper
3,415
63
109
Rogue River, Oregon
Feb 12, 2004
  • Feb 12, 2004
Troubleshooting a knock via the internet is a little tough. Whatever it is, the motor needs to come out, come apart, then you can accurately assess your options.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
