Sorry 85GTlover, but you're wrong. The front struts are not connected to the springs by any means. That's why are front suspensions are called modified MacPhearson. The job is relatively easy, but you will need an impact gun to get the top bolts off where it goes through the strut tower. You cannot spin the bolts fast enough yourself or else the strut shaft just spins when you turn the wrench or socket. Anyways, the rears are easier than the fronts, but plan on a couple of hours for the whole job if you are doing yourself without a lift.
