Replacing Speaker Cloth
  • Thread starter Thread starter toyman
  • Start date Start date Feb 17, 2008
toyman
1,944
54
79
Vernon BC
Feb 17, 2008
  • Feb 17, 2008
Sometime ago someone posted an "how to" piece on replacing the speaker cloth on his SN95 with pictures and a narration. I believe he used a red material to match his exterior. Anyone have a link to this poster? I can't find the reference either here or on google.
Zero Signal
2,633
Tucson, AZ
Feb 18, 2008
  • Feb 18, 2008
Is this the cloth over the rear dash and the door speakers? It seems to me it would only be a matter of yanking/peeling the old stuff off and using some paint on adhesive to glue new cloth on.
toyman
1,944
54
79
Vernon BC
Feb 18, 2008
  • Feb 18, 2008
The speakers are the ones set in the rear side trim (quarter) panels on a 'vert. I kind of figured that a spray adhesive would be the way to go as one of the surfaces is convex. However, the speaker grills need to be removed as the cloth needs to be wrapped over the edge and glued along the back side as well to maintain a clean look.
BTW did the lower bottom door grills have cloth on them? The upper mach system speakers have but my lower grills are plastic.
HISSIN50
34
129
Feb 18, 2008
  • Feb 18, 2008
I cant help other than to say that on my fox vert (with a similar panel, however the speaker mounted to the backside of the panel so the grill was not an issue) I used spray adhesive with no issues. The carpet tacked right back down and has been fine for years.
Zero Signal
2,633
Tucson, AZ
Feb 19, 2008
  • Feb 19, 2008
I haven't been in my car for awhile so I don''t remember. I think there is no cloth over the door speaker.
I tend to prefer actual paint on adhesive like DAP Contact Cement http://www.dap.com/products.aspx?SubcatID=8
I've used the sprays before and they worked, but the paint-on stuff is awesome if used properly.
toyman
1,944
54
79
Vernon BC
Feb 19, 2008
  • Feb 19, 2008
Thanks everyone for the input.
Sort of academic now as I mentioned what I was going to do to the upholstery shop that's recovering the seats and they offered to apply the cloth if I brought in the grills.
Leastways, I now know for the future.
Bosko5.0
1,067
longwood, FL
Feb 20, 2008
  • Feb 20, 2008
They are held on by melted plastic.
I was pulling on one of them thinking it snapped in, but it didn't.
What I did while panel was off was get a small nail hold it with vise grips heat it till glowing push into the melted plastic stud (but not to far might go through front) and pull then do the others and it shold come off.
To reattach it you can use either jb weld or equalivilant or melt some plastic back onto the stud push through the hole and heat a bolt up and push onto the stud to flatten it out so it stays.
toyman
1,944
54
79
Vernon BC
Feb 20, 2008
  • Feb 20, 2008
I managed to remove the grills by cutting away the melted part of the stud. I'll keep in mind your suggestions for next time. I was almost tempted to see if my soldering gun would soften the plastic enough to pull the stud free.
I was planning on using epoxy to reinstall. Did that on the door grill with the panel in place. Here I have the luxury of working with the panel out of the car. I might just try melting the plastic with my soldering gun.
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
Replace the entire AC charge port
  • from6to8
  • Feb 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 22, 2025
from6to8
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
