Replacing Speedo Cable.
  • Thread starter Thread starter shlby123
  • Start date Start date Feb 27, 2006
shlby123
579
Dallas
Feb 27, 2006
  • Feb 27, 2006
Getting ready to have to replace a speedo calbe. Whats the difficulty level of this type of project, and does anybody have or know of any step by step directions for this procedure?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 27, 2006
  • Feb 27, 2006
Seeing that you have chosen to hide any information about the year of your car and mods, it will not be possible to give you much help. Please update your sig in the user control panel. The sig gives us valuable information needed to troubleshoot problems, since Mustangs underwent some radical changes between 79 and 95.
shlby123
579
Dallas
Feb 28, 2006
  • Feb 28, 2006
It's just a stock LX 5.0....1989.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 28, 2006
  • Feb 28, 2006
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 cars only have a VSS sensor if the have cruse control.
Speedo cable housing assembly
without cruse control:
with cruse control
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
6.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
7.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
8.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
9.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
10.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
11.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
12.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
13.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
14.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
15.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
16.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
17.) Reconnect all the wires & connectors on the speedo head unit.
18.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
19.) Re-install the cover for the ignition switch & turn signal.
20.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
shlby123
579
Dallas
Feb 28, 2006
  • Feb 28, 2006
damn thats precise thank you so much! Thats absolutely what i needed to know. I 'll try to update as soon as i have finished!
I
Ivan_Carumba
  • Feb 28, 2006
Yes thanks JRich!
Appreciate the info as I also have to change my noisy speedo cable.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Mar 20, 2006
  • Mar 20, 2006
with cruse control
Inside the car:
Inside the car:
Inside the car:
Thanks!!! amazing what doing a search will find, I will be doing this tomorrow. I don't see a need to replace housing, so will just pull cable out like I did when I greased it before when it was noisy. Your the man!!
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Drivetrain Autometer Speedo Cable for T5
  • cbac89
  • Feb 15, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
AeroCoupe
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
