replacing tps
yes, you need to adjust your tps to .97-.99 volts with a digital voltometer. All you do is loosen both of the screws ( dont take them off ) then use the black wire as a ground and i believe its the green wire you use? Maybe someone here can clarify that. Then oce you get it to .97-.99 volts, tighten the screws back up.
txstang84 said:
hey guys, while trying to find instructions on tps voltage adjustment, i ran into this...
http://www.corral.net/forums/showthread.php?postid=3365569
can anyone confirm this?
Here is my take:
Within my understanding of the EEC, S+2B's is correct.
However, stangs were not engineered (I hope) with idle surge. So even though the puter should take care of baselining the TPS reading upon the throttle closing, I dont mind seeing people take 2 minutes to check or adjust theirs. It cant hurt in any way that I can tell, and has reportedly helped many.
vristang said:
Maybe being high is ok, but being too low is bad?
Quick - you call it. Heads or tails?
Seriously, I dont know. I really think it depends on each car - otherwise there would be a true magic number for the setting (0.97 is based upon the perceived throttle input threshold, not a magic best setting). Just my conjecture. :)
