Resealing a windshield
989153
9
Hawaii
Hey y’all I have a 65 coupe and the windshield seal is going bad. Rain leaks in through it. Is it viable to reseal it myself or should I take it to a shop?
And if I’m gonna do it how would I go about doing that
You can reseal your self . Clean all the old gunk from the channel ,i lay a couple of strips of 3M caulking ,the black type ,first . Set the window with the gasket in place ,starting at a bottom corner ,and pull the gasket over the lip . Some like to use a cord inside of the gasket to pull it over the lip but i have a hook tool to do this . Once the gasket is locked down ,carefully push down
Around the edges of the glass to seat it . Then you will need windower sealer ,caulking in the tube type ,insert the tip under the rubber in the channel and fill it up . You will also need to caulk between the glass and the gasket the same way
Reactions: 2Blue2
