I am getting my cylinder heads resurfaced due to some slight warpage (.003 across the entire head, but I want to make sure I don't blow another head gasket) If the machine shop takes off minimum amount (under .010) will the intake manifold need to be milled and will I need to do anything with the pushrod/rocker arm clearence and how would I check this? I already have a valvetrain "tick" when warm.
Also what is the common method/equipment machine shops use to resurface heads? Is one way better than another?
Thanks
Thanks
