Greetings,
(To keep it short) Can somebody tell me what I will need to remove from my completed and installed engine to confirm that the cam is not retarded??? I know I will need to take all the accessories and timing cover off if I need to change the timing chain but I just want to check the valve timing now. I assume I need to take off the crank pulley and the right valve cover to access #1 cylinder valves…. what else?
I have never degreed a cam before so I am guessing on what I need but I have a dial indicator and magnetic base but I don’t have a degree wheel. What else will I need?
The complete story:
I recently completed rebuilding my ’69 302 and am having some problems.
I started this thread about 6 weeks ago -http://forums.stangnet.com/showthread.php?t=482501
about how the engine did not have any vacuum at idle (constant 10 in.)…. Well, I finally completed putting the body back on it and was able to drive it around the block this weekend. I do have a problem. I think the lack of vacuum was just a symptom of a bigger issue.
The problem is that the engine has no pep; it won’t rev. The initial timing is set at 15 BTDC.
I think the problem is valve timing – I have checked out just about everything else (rebuilt the carb, changed plugs, wires, fuel pump, checked compression, did a leak down test, tried finding intake leaks). I did not degree the cam and I think it must be retarded too much. The low steady vacuum is a classic symptom of a retarded cam.
Help?
Thanks!
The complete story:
Help?
Thanks!
