retrieving codes
  • Thread starter Thread starter theconductor
  • Start date Start date Nov 7, 2007
theconductor
337
96
74
Roseville, CA
Nov 7, 2007
  • Nov 7, 2007
I plugged in the code reader today to see what I had. The only thing that happened was my fuel pump started running and wouldn't stop until I turned the reader off. No codes ever came across.
What the hell could be wrong? I thought that even I could figure how to get a code from my engine!
Kyle
bloopbloob
578
Alberta
Nov 7, 2007
  • Nov 7, 2007
mine didnt work the first few times either, but i could hear the car doing checks. i cant for the life of me remember how i got it to pull codes though. sorry! no problems since then though. i'd just keep trying it, maybe play with the connections a bit....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 7, 2007
  • Nov 7, 2007
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
theconductor
337
96
74
Roseville, CA
Nov 8, 2007
  • Nov 8, 2007
I have the scanner. I just can't get it to give codes. I won't even give the everything is okay code. I can hear things clicking, but in the end all that happens is the fuel pump stays running until I turn off the test. It doen'st stop and give any codes. I will try the "jumper and check engine light" method to see if I have any better luck.
Thanks
Kyle
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
