reuse old pinion nut?
rockyracoon
874
27
49
margate NJ
Is a new one an absolute necessity?.I want to get my beast back on the road and I dont think I can get one locally.also is it ok if I used a different inner pinion bearing with the race thats in the housing.
I have done both on two occasions in addition to reusing the crush sleeve and both gear installs went just fine with silent gears.
Just put lots of threadloc on the pinion nut so it doesnt back off.
you should be fine reusing the pinion nutz, like pete said if you use some loc tit. Im not sure about the inner pinion bearing. I put in all new bearing on the same chuck, my bro-inlaw does so many rear ends cuz the new f-150s that he did the whole job by feel. The thing is unbelieveably quiet too.
supposedly the pinion nut's threads are designed to deform or something like that so when you tighten it down, it will never back off on it's own.
Sort like the crush sleeve. This is why you cannot reuse one. But if you take other precautions like loctite then you dont need the nut itself to be "locking", you provide the locking force through some other means.
