Rev limiting problem
  • Thread starter Thread starter Carb'dCobra
  • Start date Start date Oct 31, 2006
First Prev 2 of 2
C
Carb'dCobra
26
Tampa, Fl
Nov 1, 2006
#21
  • Nov 1, 2006
  • #21
795.0pacecar said:
Bad move, you can get a pretty decent chunk of change for a complete wiring harness. Unless it was all hacked up, then I would have saved it for the connectors and what not.
To expand upon that, the harness was hacked up, and I didn't need the connectors, I have a fabricated aluminum dash with everything wired to independent switches.
C
Carb'dCobra
26
Tampa, Fl
Nov 1, 2006
#22
  • Nov 1, 2006
  • #22
Just so you know, the only thing remotely stock in the motor is the block and it was cryo treated by CryoPlus, lifters aren't stock either
. Also, it's not possible to have billet rods with a billet crank . I might not "know everything" but I do know my motor.
P.S. Jesus, how much would a billet crank weigh anyway? Wouldn't it be a bad idea anyway just because of the weight?
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Nov 1, 2006
#23
  • Nov 1, 2006
  • #23
Ah, I see.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Nov 1, 2006
#24
  • Nov 1, 2006
  • #24
It will rev to 7000+ RPM, but if you knew your motor you would know it wont make power that high. Probably be done by 6000 RPM, but like stated above time to change the Dist. etc...
ninety15.0
1,336
#25
  • Nov 2, 2006
  • #25
this is kind of a stupid thread. What exactly are you asking? It seems like most people have been saying the same thing. Your running out of power at 5900?!...honestly that sounds perfectly normal for ported E7's and a b-cam. You have a stock style valvetrain...no shaft mount rockers or titanium components. Quite simply the motor isnt built for 7k+ rpm...its built for 6k tops. I think you just need to start shifting at 6k...especially if it feels like the car is running out of steam at 5900. it just seems logical
ninety15.0
1,336
#26
  • Nov 2, 2006
  • #26
Im also just realizing that we dont know about your intrumentation issues. You cant trust the stock tach as far as you can throw it. Horrible inaccurate. Hopefully you have a nice autometer or something comparable to know the true rpm. you said you have an Al dash so hopefully you got rid of stock instrumentation.
First Prev 2 of 2
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
Engine LOSS OF POWER AT 4,000 RPM.
  • Jarhead67
  • Nov 17, 2024
3K
Fox 5.0 Mustang Tech Jan 25, 2025
Jarhead67
J
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
