Rewiring Mach 460??
ok, well, before any one says that I should just get an aftermarket cd player, and rewire it all now, this is what I got, and it was all free, so I'm going to stick w/ this for now at least :D
I'm attempting to remove the stock mach 460 wiring harness behind the headunit, and add a different type, w/ new wiring and an add cd harness included. not to mention, a new ground (I'm getting interferience now :mad:) so, I can remove almost all of it, but that little clip (w/ the yellow wire on it) is giving me a ton of trouble! it's way up in the dash, behind the gauge panel, and the steering setup is getting in the way... any suggestions? also, does anyone know where the harness from the front, connects to the rear harness wiring? that would be helpful to know too, along w/ where that ground wire actually is connected to the frame (the one about a foot in the wire before the connection between the two harnesses is made. thanks guys.
To answer your questions:
1. Remove your driver's seat - you'll need a 15 mm socket, it's easy, and it'll give you room to work on your back, which will make your job easier.
2. The front and rear Mach 460 harnesses meet behind your driver's side cowl trim panel, where the hood release is at (at least that's where it meets in my car).
3. The ground wire connects to a screw on the metal frame holding the low current fuse box, under the left side of the instrumentation panel next to the hood release.
Good info...(in case I may need this in the future)
RC
thanks jason... I can't tell you how helpful that was... although, once I actually got the seat out (btw, tried it w/ the seat in at first, using towels to pad my back... that way didn't work well at all!!!) saw the ground right in front of my face, and once the panels on the side were out (btw, just clip in!, no screws at all, THANK YOU FORD!) saw the meeting place, but that gave me some good confidence...
-got the new front harness, 2 rear amps, and new speakers in today, along w/ the new headunit, and CD player... man, does it sound better!! no interferience, no raspy rattle w/ high bass, and, I have a cd player now! :banana:
thnx guys... next time (which there never will be a next time) it should be much easier :nice:
