Riddle Me This Knock
  • Thread starter Thread starter elarm1
  • Start date Start date Jun 4, 2014
1 of 2 Next Last
elarm1
1,428
652
154
N.Va
Jun 4, 2014
  • Jun 4, 2014
I was cruising along about 5 miles away from home and I start to hear a disgusting knock. At first thought I say I must have cleaned out a bearing but I don't know. I changed the oil and saw no glitter or shavings (check one). Pulled the vc's to see if it was possibly a bent push rod or roller rocker out of wack....nope (check two). Listened for the noise with a scope all around the motor and the sound is very hard to pin point. If I put my ear to the intake I hear it the loudest and to the back of the motor around the bell housing I hear it the loudest. The last check I did was pull each plug wire while the car was running to see if I could get the knock to change a note. NO MAS! What could my knock be?
stykthyn
5,232
2,652
223
gainesville
Jun 4, 2014
  • Jun 4, 2014
Bad mount maybe? Exhaust hitting on the tunnel?
elarm1
1,428
652
154
N.Va
Jun 4, 2014
  • Jun 4, 2014
I have solid mounts. Exhaust seems not to be touching but the sound is more mechanical and speeds up as the engine speed is changed.
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Jun 4, 2014
  • Jun 4, 2014
collapsed lifter? throw out bearing by chance?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 4, 2014
  • Jun 4, 2014
I chased a distinguishable knock around for a couple of days last summer and it turned out of all things to be a loose plug wire. Put it back on and the knock was gone.
Have you made any changes to the car recently that could contribute to the noise?
FoxMustangLvr
I love my Pimp
SN Certified Technician
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 4, 2014
  • Jun 4, 2014
Who's there?
Reactions: dnbonds
elarm1
1,428
652
154
N.Va
Jun 4, 2014
  • Jun 4, 2014
I thought of the lifter but after running the engine with the vc's off, I couldn't distinguish if if could be that. Clutch pushed in or out, the noise is still there. I haven't made any changes to the motor at all. I initially thought it was an out of adjustment roller rocker but I set them to specs and I have the same noise. The car runs fine other than the knock. Oil pressure on my guage is above 50 at start up and hangs around 40-45 when its running.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 4, 2014
  • Jun 4, 2014
Gotta give us some more info man.
Does it knock all the time, or only during cold start?
Does the knock get quieter as the engine warms up?
Is the knock in sync with engine RPM,
Does this happen when driving, or sitting at idle, or both
Have you made any other mods to the car (not just engine mods) that could contribute to the noise? For example, a new clutch and flywheel could be making slight contact with the bell housing, creating the sound you hear.
No chance said "knock" is some fort of exhaust leak? A header leak can sometimes fool ya.
elarm1
1,428
652
154
N.Va
Jun 4, 2014
  • Jun 4, 2014
The knock is there all the time and is in sync with the rpms. It's there all the time at idle or driving. My next move is to disconnect the transmission to see if I see anything wrong. This knock reminds me of a rod bearing or maybe even something coming into contact with something. The sound is more at the back of the motor which makes me want to drop the trans but it could just be sound resonating
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 4, 2014
#10
  • Jun 4, 2014
  • #10
Did you check your plug wires to see if they're all on tight, and/or in good shape? And arking, or loose plug wire can sound like engine knock.
elarm1
1,428
652
154
N.Va
Jun 4, 2014
#11
  • Jun 4, 2014
  • #11
They are all tight. tonight I will be taking out the transmission to futher diagnose issue
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jun 4, 2014
#12
  • Jun 4, 2014
  • #12
Possible loose flywheel? I've seen this more than once and it is hard to differentiate from a rod knock
toyman
1,944
54
79
Vernon BC
Jun 4, 2014
#13
  • Jun 4, 2014
  • #13
The flywheel being loose reminded me of an event some years ago. In my case the knock was from the flywheel, not because the bolts were loose but rather because it cracked between the mounting bolts. When the bolts were removed the flywheel came out in two pieces.
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Jun 4, 2014
#14
  • Jun 4, 2014
  • #14
FoxMustangLvr said:
Who's there?
Beat me to it
modulistic
383
30
29
Jun 4, 2014
#15
  • Jun 4, 2014
  • #15
i rebuilt a chevy 350 with a bad knock. it was strange as hell because all the bearings looked great. when one of the pistons came out, a piston ring was broken and fell out in two pieces.
elarm1
1,428
652
154
N.Va
Jun 4, 2014
#16
  • Jun 4, 2014
  • #16
This is what I'm thinking but I won't know until I tear her down but this View: https://www.youtube.com/watch?v=vNVUMx_rJWA
is what I am hearing
elarm1
1,428
652
154
N.Va
Jun 4, 2014
#17
  • Jun 4, 2014
  • #17
FoxMustangLvr said:
Who's there?
Dees...
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Jun 5, 2014
#18
  • Jun 5, 2014
  • #18
elarm1 said:
Dees...
Nuts? lol
FoxMustangLvr
I love my Pimp
Oct 14, 2012
4,968
3,514
204
Spokane, Wa
Jun 5, 2014
#19
  • Jun 5, 2014
  • #19
84Ttop said:
Nuts? lol
You're not playing right, you're supposed to say "Deez who?"
89stang1
Stroked and Juiced
730
234
74
nj
Jun 5, 2014
#20
  • Jun 5, 2014
  • #20
dam that sounds just like when one of my cheap asss afr rocker studs broke you could feel the pushrod hitting the valvecover. How is oil pressure and does car drive normal
1 of 2 Next Last
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
