  • SN95 4.6L Mustang Tech
Electrical Right Side Brake Lights Not Working
  • Thread starter Thread starter Sonic04GT
  • Start date Start date Jun 4, 2017
Sonic04GT
844
West Palm Beach, FL
Jun 4, 2017
  • Jun 4, 2017
2004 GT
Running lights, hazard lights, turn signals, reverse lights all work perfect. All bulbs illuminate normally, dim for the running lights, and bright for the hazards/turn signals.
However, when I press the brake pedal, only the left side and third brake light illuminate. Any ideas?
I have visually inspected both 15 amp fuses under the dash and they appear fine.
-(33) 15A Stop lamp switch, Speed control deactivation switch
-(41) 15A Brake lamp
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 5, 2017
  • Jun 5, 2017
When the right turn signals are used does the turn signal on the cluster work as well?
I'm having some "issues" with my Ford wiring diagrams right now but I'm thinking the problem is in the multi-function switch.
Note, it's possible to rebuild your own multi-function switch. Recommend taking a ton of pictures when taking apart. Clean and apply di-electric grease to all connections.
Sometimes you can restore function by working the hazard button up/down a bunch of times.
Sonic04GT
844
West Palm Beach, FL
Jun 7, 2017
  • Jun 7, 2017
Yes, the turn signal on the cluster does work normally. I haven't gotten the chance to check them after cycling the hazard button.
Sonic04GT
844
West Palm Beach, FL
Jun 7, 2017
  • Jun 7, 2017
I disconnected the harness in the trunk and pulled the housing/lens out today. Pulled the bulbs, inspected, and reinstalled everything. Maybe wiggled some wires around. It works now!
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
C
Another lighting issue
  • ChrisCruz1972
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
Z
Right side of cluster not illuminating 91 LX Hatch
  • Zeke1995
  • Jul 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2025
General karthief
