Jason 302 10 Year Member Aug 9, 2003 685 71 68 Newark, Ohio Jan 2, 2006 #2 Jan 2, 2006 #2 Mains = 65 ft/lbs Rods = 25 ft/lbs for stock. ARP calls for 28 ft/lbs.
Rick 91GT Mustang Master Nov 29, 1999 9,692 95 99 PA Jan 2, 2006 #3 Jan 2, 2006 #3 Stock bolts/studs or aftermarket bolts/studs? Moly or oil?
TheBocSez New Member Feb 3, 2004 652 0 0 Converse, TX Jan 3, 2006 #4 Jan 3, 2006 #4 Here is a link from Summit with torque specs for stock bolts using 30wt oil. http://www.summitracing.com/streetandstrip/charts_guides/charts_fordtrq.htm But as Rick91GT said, aftermarket fastners require different specs and if you use a moly lube, it changes them again. If you are using ARP bolts, follow their recommendation and use the moly lube over the 30wt oil.
