rod bearing clearances using .001 bearings
dastang2
2,020
tx
hello, i got a crank from a good machine shop that mic'd the crank and said it is still std. but to use .001 bearings on it. i think that is just for the rods. so i did and put it in my other block. it has been a good while,over a year since i turned the motor by hand. i do not remember if i could or not without using a wrench. now i got a different motor that i decided to change the crank and bearings on. so i took the crank out of the old block along with the good never used bearings. i put them in this new block and now i can only turn the crank with a wrench.(remember that i can not remember if i used a wrench or not but i think i did.) i torqued the rods to 40 but i have an old torque wrench that only has a pointer on it and i think it is bad now since i snapped a rod stud with less than 40 psi as the wrench said. i am using lube. i plastigauged the bearings again as i did when i put the .001 bearings on with the crank in the old block and it was the same as what i got before. .015 is what it came out to be for rod bearing clearance and i was told this was an acceptable clearance. i did take the rod bearing out and look at them again and no wear, so i am thinking i just need a better torque wrench. i was thinking this is just going to be a tight clearance motor and may need thin oil for a while or something. can anybody help me out here. thanks. the new shortblock i have turned by hand but it also had some moderate wear on the main and rod bearings. i did nothing else but change bearings and crank.
it measured out to be .002 of an inch in the main bearings. is this a good clearance.
checked the rod clearance and got .0015 and no taper at all, i heard this is good. is it
this is a post from a different site that i looked up from. maybe it was .0015 of an inch instead of.015 of an inch. i may have forgotten ot misread the sheet of paper that came with the plastigauge. thanks all.
.002 on the mains is the happy medium for a performance street engine. Race engines usually have ~.0025 and stock engines are tighter at ~.0015. The rods are about right.
40lbs is too much for the rod bolts. It shouldnt have broken, though. A decent beam torque wrench works fine and they take ALOT of abuse before wearing out. Craftsmans are only ~$30.
really ony 25, i was looking at a book i have with specs and it says 40-45 psi. that should be my problem right there. i did however borrow a better wrench from autozone and i am going to complete the bottom end today. thank you all.
those specs are at 40 psi i am going to take another look really quick but thanks. i am relieved, i may have looked on the wrong line since all the numbers are bunched up.
