hllon4whls is correct 6" x 6" 1/8", you can bend the plates to fit where you want them.
If you weld the bar inbetween the shock towers, make sure you plate them, they will only be like 3" x 3" but some inspectors are being picky about that, just beat the plates to form them to the shock towers. Also put in 2 small wedges to connect the bar to the frame, basically you tap them into place under the bar them weld them in.
I've seen 2 cars fail NHRA inspection with out the snubby pieces, becuase some inspectors do not count the shocktower as a frame attachment point.
How's the project coming? Haven't heard from you in awhile...
