While in the process of heating up my combo, I was able to pick up a full lifter/pushrod/rocker and spider kit for a hyd. roller cam. However, my understanding is that the older blocks do not have the spider mounting holes machined into the top of the lifter valley. I've been advised by my builder that to machine these holes, I would need to pull the engine and drop the rotating assemblies, as there is a possibility that the cam bearings might get damaged in the process.
With that said, I think there are 2 options:
A) Remove the engine, rotating assemblies etc and get the pider mounting holes machined, or
B) Buy the lifter retrofit kit that has the lifters with the bars that span bewteen the pair.
Cost for option A is being quoted around $350, plus my labor in pulling the block. Cost for option B is quoted around $550 and is virtually a drop in affair.
Are these my only options? Can the spider mounts be machined without removing the block? Are there any limitations in reliability/efficiency/performance in going either route?
