Rotate Engine via wheels????
  • Thread starter Thread starter chobracobra
  • Start date Start date Nov 29, 2006
chobracobra
175
jersey shore
Nov 29, 2006
  • Nov 29, 2006
Im doing a valve spring swap, and was wondering if it is possible to put the tranny in 5th, remove the spark plugs, and get two guys to rotate the rear wheels? will the motor turn relitivly easy?
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 29, 2006
  • Nov 29, 2006
I was able to push my car in gear. because i over tightned the rocker arms..
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 29, 2006
  • Nov 29, 2006
If you have two strong guys you may be able to do it.
The car will roll very easily in 5th gear on a hill if you let it roll.
chobracobra
175
jersey shore
Nov 29, 2006
  • Nov 29, 2006
i just rasied one side and turned the wheel by myself. when the spark plugs are in, its imposible.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 29, 2006
  • Nov 29, 2006
Use a 15/16 socket with a short extension and a breaker bar on the harmonic balancer bolt. Just be sure to turn the engine clockwise so that you don't loosen the bolt.
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 29, 2006
  • Nov 29, 2006
Grr..i forgot about the balancer bolt.
If you take the spark plugs out, you can actually grab the crank pulley with your hands and spin it.
With the plugs in you need a rachet
  • dan50
  • Jul 18, 2026
dan50
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
