  • SN95 4.6L Mustang Tech
Rotating Assemblies - got a few Q's?
  • Thread starter Thread starter Fubar02GT
  • Start date Start date Oct 22, 2005
F
Fubar02GT
73
Bradford
Oct 22, 2005
  • Oct 22, 2005
Well, i'm thinking of playing it smart before i get stupid and actually building the bottom end first. I haven't found any really good deals on rotating assemblies so far, except from Sean Hyland. It appears the 4.6L Forged rotating assemblies right now are 1495 and to go 5.0L stroker it's 1995...
http://www.seanhylandmotorsport.com/online/product_info.php?cPath=65&products_id=1171
my first question would be is it overall worth it for the extra 500 bucks to go to a 5.0L? what clearencing is required with a stroker crank in these blocks? i'm at a loss as to what to do with the pistons. Basically i'm unsure wether i want to run boost or juice. I'm figuring a fairly high compression 5.0L for juice would be nice, but then if i ever strip the NOS i'm kinda dicked for boost. My orig. plan was for a Vortech mongoose kit...i'm kinda torn really. Any ideas as far as that's concerned? i figured i could get the plate kit now, play with a 100 shot, forge the bottom end, and rack up the shot come summer...or keep the compression and the NOS respectable, and just add the vortech as money permits...
thoughts...suggestions?
F
Fubar02GT
73
Bradford
Oct 23, 2005
  • Oct 23, 2005
ttt
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Oct 23, 2005
  • Oct 23, 2005
who do you plan on assembling the shortblock? personally i'd rather get one from someone i trust already assembled. N/A you'll gain torque with the 5.0L but lose some power up top with the stock heads/cams. FI or with ported heads they will produce more upper rpm power. is it worth it? depends on your goals and how much you are willing to spend.
Word_Life
Banned
Jun 30, 2005
51
East Coast Lyfe
Oct 23, 2005
  • Oct 23, 2005
If you go for a 5.0 Stroker you' have to have the block machined.
SHM has been known to shaft people lately. Choose someone else.
ponysarepretty
578
  • Oct 23, 2005
I think a lot of people seem to have misconceptions about torque and power, power is a function of torque. if you gain more torque you will gain more power, however if you lose torque and rev higher, you may still gain power.
anyway the equation is:
hp = rpm*tq/5250
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Oct 23, 2005
  • Oct 23, 2005
if you plan on getting a rotating assembly you actually can have them drop the compression ratio if you plan on going supercharged. Same deal for your forged bottom end but it all comes down on what you really want to do either nitrous or FI.
F
Fubar02GT
73
Bradford
Oct 23, 2005
  • Oct 23, 2005
i guess i'll be staying 4.6 then for now, because i lack the cash for the machine work, however i am confident in my engine building skills. I've done my TSi twice, the big block for my corvette, a friends LT1, and a couple 5.0's so i think i should be able to handle a modular. I'd also rather do it myself so i know if i grenade it...it truly was my fault...
who would you suggest for a fully forged rotating assembly then?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Oct 23, 2005
  • Oct 23, 2005
YES everyting pistons, rods and get a cobra crank
F
Fubar02GT
73
Bradford
Oct 23, 2005
  • Oct 23, 2005
any particular vendors is what i actually meant. i pretty much knew it was gonna be a cobra crank but what about the internals? i'm not sure about a drop in compression. isn't ours already low as it is comparatively to other motors?
V
VividDreams
200
Lebanon County, PA
Oct 24, 2005
#10
  • Oct 24, 2005
  • #10
Check out Coast High Performance at http://www.coasthigh.com/Assemblies/Ford/ford_4_6.htm
the Nodular iron that the cranks are made of in their street fighter kits are supposed to be pretty strong
or you could step up to their cast steel units
all kits us Probe Pistons
F
Fubar02GT
73
Bradford
Oct 25, 2005
#11
  • Oct 25, 2005
  • #11
I did get a quote from VT, and based on the price/quality/rep...they appear to be the front runner. Might even try to score a set of stage 2 blower cams from them as well since the motor's gotta come apart might as well do the top end too!
D
Drag_on
24
#12
  • Oct 27, 2005
  • #12
Don't even look at coast high. You will need some better pistons than probe.
V
VividDreams
200
Lebanon County, PA
Oct 27, 2005
#13
  • Oct 27, 2005
  • #13
really, probe isnt good? theyre forged.....a lot of race cars use probe....
dunno
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 27, 2005
#14
  • Oct 27, 2005
  • #14
d00d you're close to Kaffmans give them a ring and see what say
Engine Suggestion On Shortblock Or Rotating Assembly
  • DJsZincGT
  • Jul 22, 2015
SN95 4.6L Mustang Tech Jul 28, 2015
Three50won
Engine I-beam V. H-beam Connecting Rods
  • loyalblue
  • Jun 20, 2015
Fox 5.0 Mustang Tech Jun 23, 2015
FastDriver
  • Locked
Eagle 331 forged rotating assembly
  • pro50
  • Feb 6, 2012
  • Engine and Power Adder
4K
Engine and Power Adder Feb 18, 2012
pro50
  • Locked
Expired Bunch of PARTS FOR SALE! Going Street car only
  • 1200gt
  • Feb 5, 2013
  • Other Classifieds
2K
Other Classifieds Feb 12, 2013
1200gt
Made a decision....finally
  • GameCock5.0
  • Feb 11, 2012
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 16, 2012
StreetsideStig
