  • 1994 - 1995 Specific Tech
Rough idle and ping
  • Thread starter Thread starter rulesR4suckers
  • Start date Start date Jul 10, 2005
R
rulesR4suckers
72
Fairview Heights, IL
Jul 10, 2005
  • Jul 10, 2005
I need some help guys. I'm new to Mustangs and I'm learning as I go. Here's the deal; my car has a rough idle. On the scale of 1 to 10 I'll give it a 4, so its not to bad. If I listen to the exhaust note at the rear of the car the passenger side sounds choppy, but the driver's side is all fivers. And also, above 2000rpm there's a pinging, don't know if its from bad gas or timing or both. I really started to notice this ping yesterday when I changed out the factory H-pipe. Please help me!!!!
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jul 10, 2005
  • Jul 10, 2005
Clean the MAF sensor. Use alcohol and a Q-tip. Be very careful..... they're fragile wires. That may help. Maybe not. I'd try it. I'd also clean the IAT sensor while you're there.
R
rulesR4suckers
72
Jul 11, 2005
  • Jul 11, 2005
I did some research and found out that I had to reset the computer. I did that and it seam to have worked.
R
reldapimp
94
  • Jul 12, 2005
sorry asked a question but a simple search got me my answer.
HISSIN50
34
129
Jul 12, 2005
  • Jul 12, 2005
We will keep the thread around in case it comes back.
Justin had some sound advice if it does.
Good luck.
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
