Rough idle
  • Thread starter Thread starter 70mustanguy
  • Start date Start date May 8, 2011
70mustanguy
15
  • May 8, 2011
I have a rough idle in my project car. I have started it up and everything seems steady besides the rough idle. I did a vacum check and got a good steady 20 inch. I think can be the timing ( have been playing around with it but am not getting anything to stop the rough idle), bad spark plug, or bad cylinder( hope not). I don't have the best knowledge of mechanics since I am only a high school student. But I have played around with it and am not sure whats with the idle. Any sugestions would be helpfull thanks.
G
gregski
577
Sacramento, California
May 8, 2011
  • May 8, 2011
I love rough idle threads, get ready for a 1,000 opinions, LOL, all I am going to say is check the simple stuff before you tear into that engine.
Whacha mess with last, tell us more?
Where is your timing set at?
Did ya tinker with the carbie?
Old spark plugs or new?
Old spark plug wires or new?
RUNNING ON OLD GASOLINE PERHAPS YOU ARE?
skywalker
733
Pensacola, FL
May 8, 2011
  • May 8, 2011
I second that.
Other questions: do you have an electric choke? Do you know what kind of cam you are running? Is your idle fast enough? What kind of carb are you running? While your vacuum gauge may say 20 inches, I know the Holley procedure is to start out at a standard setting, likely too rich and too fast, adjust the mixture to achieve MAXIMUM vacuum and then adjust the idle speed. If your idle mixture is off (or asymmetric) it can cause a rough idle, a fast idle and dieseling.
67rcks
373
May 9, 2011
  • May 9, 2011
skywalker said:
I know the Holley procedure is to ... adjust the mixture to achieve MAXIMUM vacuum and then adjust the idle speed.
IMO it is not as simple as that. You can adjust idle speed so that .040" max idle slot is revealed. If idle is still rough you likely have some dirt idle/transition passages (assuming correct valve+ignition timing, no vacuum leaks, functioning power valve, etc.) Idle has to work on all secondaries too! It is one of holley's imperfections that you must tune idle air through main system, and there's no separate idle air tuning screw as in other carbs.
G
gregski
577
May 9, 2011
  • May 9, 2011
Does he even have a Holley? LOL
skywalker
733
Pensacola, FL
May 9, 2011
  • May 9, 2011
Hence why I asked what kind of carb
skywalker
733
Pensacola, FL
May 9, 2011
  • May 9, 2011
In so far as there being another problem, you are right. In so far as a rough idle due to a poor tune, it is as simple as that though. You need a small flathead, a vac gauge and a tachometer and that is all to tune your idle. The tachometer part can be bypassed with decent ears.
globaltefl
54
Grand Junction, CO
May 10, 2011
  • May 10, 2011
Has anyone tried the PROZONE IDLE CONTROL valve? Are they any good?
skywalker
733
Pensacola, FL
May 10, 2011
  • May 10, 2011
The wha?
M
Idle control valve
  • miser143
  • Saturday at 9:40 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sunday at 11:18 AM
General karthief
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 25, 2026
roldy
R
