  • 1994 - 1995 Specific Tech
Rough, Lumpy Idle (long)
  • Thread starter Thread starter Synned
  • Start date Start date Apr 8, 2007
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Apr 8, 2007
  • Apr 8, 2007
Hey guys, whats up...
Well I just got my car back up and running, got the timing set yesterday as well.
It runs fine, feels like it has power and drives pretty normally.
My one problem is the idle. It idles like its cammed, sounds pretty cool but it kinda surges too. If I come to a light it'll happen too. This morning it was pretty bad sounded like it was close to dying.
One thing I noticed is on the IAC valve...the connecter wouldn't fit with the new elbow adapter, I had to trim some plastic off of the side of the connecter, and it still isn't completely snug on there- but still making a connection.
So what do you guys think? IAC, EGR? No check engine light...should I pull codes for the heck of it? The IAC was never off of the throttle body. I probably still have some vacuum leaks to take care of, right now the ports are sealed off with electrical tape haha.
Thanks for all the help guys
Joe
:SNSign:
Synned
Mar 31, 2005
991
Philly
Apr 8, 2007
  • Apr 8, 2007
ttt
juiced_94gt
1,143
Southern California
Apr 8, 2007
  • Apr 8, 2007
The vacuume leaks are what's causing this most likely
HISSIN50
34
129
Apr 8, 2007
  • Apr 8, 2007
I gotta agree. The leaks really are not helping things, especially on an Auto, where the idle tends to be set lower (than a stick) so you feel every burp.
Good luck Joe.
Synned
Mar 31, 2005
991
Philly
Apr 8, 2007
  • Apr 8, 2007
You guys are probably right...its weird though it smells very very rich, like straight gas.
CE light came on while driving, stored codes are:
181 - Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
211 - Ignition PIP signal was erratic or missing - Ignition Systems
(I think that was because I was turning the distributor trying to get the timing set, I kept hearing the fuel whine up I guess the car thought it was cranking?)
KOER codes are:
172 - Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
136 - Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
Everything pointing to lean...lean lean lean. Vacuum leaks, here I come.
In terms of what I have hooked up,
The big fat line coming off of the vacuum tree is going to the port coming off near the throttle body, also where the regulator on the fuel rail is.
Theres another coming from the T near the charcoal canister going to a port on the back of the upper, and the PCV going to the rear of the upper.
Theres two ports that I sealed off.
juiced_94gt
1,143
Southern California
Apr 8, 2007
  • Apr 8, 2007
It smells rich because of the leaks, plug them up, your codes will go away, and it will smell sanitary.
4G-KDMP
935
CA
Apr 9, 2007
  • Apr 9, 2007
you need to fix those leaks or you'll just keep get codes and not know the exact problem.
Synned
Mar 31, 2005
991
Philly
Apr 9, 2007
  • Apr 9, 2007
Aight, replaced the two vacuum ports with rubber vacuum guys, cai is still leaking a little Stupid ebay cai wrong coupler sending idiot!!
mustang6tee8
375
College Station, TX
Apr 10, 2007
  • Apr 10, 2007
check PCV valve? that made my idle really rough
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
