Royally P/O'd, vibration problem
  • Thread starter Thread starter fly4spd
  • Start date Start date Apr 26, 2005
fly4spd
118
Las Vegas & Reno
Apr 26, 2005
  • Apr 26, 2005
I took my car into a local shop, because i don't have the tools or time to replace the transmission. They suggested that i replace U-joints, which sounded like a good idea, because they probally haven't been changed in 22 years. I was replacing the tranny because of it locking me into 4th gear randomly, so i picked up a tranny from a guy in my mustang club and took everything to the shop, (also bought a steeda tri-ax).
When i picked it up this morning (about an hour ago) they told me that the gear were loud, which i wasn't too worried about because the shifter lacks the bushings to keep the noise down. The noise is extremely loud. But i decided to take it for a test drive to make sure everything else was cool. i hit about 40 MPH and the car starts shaking really bad, i hit 50 and the vibration makes me feel like the tires are coming off the ground. I went back and they said that the tranny probally has a bad input bearing. That didn't make much sense to me so I took it for another test drive and found that the vibrations are TOTALLY speed related, and not RPM. This is where i need help, if it is speed related that makes me believe that the new U-joints (they are new, i looked) made the drive shaft out of balance, since it isn't RPM related I don't think the vibrations are from the tranny. (the noise probally is and i'll deal with that later, i just want the car to be drivable at the moment) The vibrationis don't depend on what gear i'm in, even in neutral with the clutch in at 40 MPH the car vibrates (more like violent shaking). Please tell me if i'm thinking correct before I start threating to take heads.
Thanks
-aj
UMDSmith
226
Salisbury, Maryland
Apr 26, 2005
  • Apr 26, 2005
if its speed related, and not RPM, it would have to be related to the joints/rotating assembly or their install.
fly4spd
118
Las Vegas & Reno
Apr 26, 2005
  • Apr 26, 2005
Thats what i'm thinking, i just want to verify, can anyone else verify that's what i'm thinking
old_blue
1,783
282
124
Apr 26, 2005
  • Apr 26, 2005
maybe try putting the old tranny back in and seeing if it makes the vibrations with the new u-joints.
fly4spd
118
Las Vegas & Reno
Apr 26, 2005
  • Apr 26, 2005
i wish i could, but the problem is that i don't have the tools or place to do it... thats the reason i took it to a shop to begin with
1989monstang
  • Apr 26, 2005
Get it done quickly! my best friend car was doing the same thing the night he got killed in a car accident in his 5.0 back in november. Not trying to scare you, but safer is better. Good luck
88GTtom
198
Woodbridge NJ
Apr 26, 2005
  • Apr 26, 2005
get an aluminum drive shaft.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
