RPM dip braking hard AND high speed vib.
whtvenom96
Hello all
I have 96 cobra. When I stop fast my rpm's dip below normal idle(probably 150rpms or so) then they come back up after a second. Does something need adjusting or cleaning.
A second issue is a vibration once I hit about 75mph. I don't feel it in the steering wheel. Really only the shifter. I only remember noticing it after have my clutch replaced. The shop looked at it and said they don't think its the clutch. What are some things I could check. I would prefer to start by replacing the cheapest components first.
THANKS in advance!
Vibration did they index the drive shaft when they had the trans out for a clutch. The idle issue, your throttle plate most likely needs to be adjusted for off throttle position when warm or you have a lazy Iac (idle air control)
20yrs in viberations specialist.dont always believe what u read.your driveshaft was not balanced with pinion flange hench anyway is correct.any change in vib thier would indicate problem from thier back.a 2 piece shaft to doesnt have a oneway fit needs index on shaft itself .also note a true driveshaft vib is 35t65 and arnt normally hi speed vibs.objects that remain a constant speed vib.wheels are mostly 99%.in your case sounds i look at out of balance pressure plate .im not saying your shaft is not at fault .the shop could have damaged your shaft or did they do any work on it?
