rpms
  • Thread starter Thread starter Alarus
  • Start date Start date Aug 26, 2005
Alarus
226
Az
Aug 26, 2005
  • Aug 26, 2005
what would a good red line for a 73 302 be, installed a tach and now i just wanna move the needle to were a good redline is, dont think its 4k.
krash kendall
1,258
Aldergrove, B.C. Canada
Aug 26, 2005
  • Aug 26, 2005
I keep mine below 4500 RPM, just for the cost of gas.
Alarus
226
Az
Aug 26, 2005
  • Aug 26, 2005
cruzing i try to keep it at 2-2.5k witch keeps me at about 60-65 mph i just wanna know what the redline is so i dont hurt the poor little engine if i ever decide to play
krash kendall
1,258
Aug 26, 2005
  • Aug 26, 2005
Wow that's low. At highway speeds I'm around 3800 with the C4 and 3.50 gears. A 302 will easily stand up to 4500 and with some work can get up to 6500.
12sec67
1,301
San Diego, Ca
Aug 26, 2005
  • Aug 26, 2005
stock 302... 2 or 4 barrel?
Max Power
1,774
St Paul
Aug 26, 2005
  • Aug 26, 2005
Tough question to answer without knowing anything about your engine...
coolblue65
1,224
Algonquin, IL
Aug 26, 2005
  • Aug 26, 2005
If it is bascially stock your redline is probably between 5200-5500. Back when I first got mine it would start breaking up around 5500.
Are you running points in your distributer?
Alarus
226
Az
Aug 26, 2005
  • Aug 26, 2005
car is a 73 coupe, 302, Points, 4bbl carter, and a performer manifold, and a c-4 tranny other than that its compleatly stock (as far as i know)
How can i tell what rear end gears i have?
12sec67
1,301
San Diego, Ca
Aug 26, 2005
  • Aug 26, 2005
what is you rpm at 65... so we can give a rough estimate or you can crawl under your car and look at the tag on the rear end being held on by the bolts.
Alarus
226
Az
Aug 26, 2005
#10
  • Aug 26, 2005
  • #10
rpm at 65 is 2.5-2.6k
Alarus
226
Az
Aug 26, 2005
#11
  • Aug 26, 2005
  • #11
it looks like the p/o had rearend work done on it, theres silicone on it and it dosnt look no 32 years old...and i couldnt find a tag when i got under it.
Max Power
1,774
St Paul
Aug 26, 2005
#12
  • Aug 26, 2005
  • #12
With a stock valvetrain, you will probably be getting valve float at about 5000 rpms.
mudbilly
175
South County, Maryland
Aug 29, 2005
#13
  • Aug 29, 2005
  • #13
if you have standard diameter tires (about 25 inch), you have a 3:0 rear
mudbilly
175
Aug 29, 2005
#14
  • Aug 29, 2005
  • #14
red line question
i've always wondered.........
what determined the factory red line rpm on these cars?????????
did the valves start to float??? did they figger that if you went 500 rpm over the redline the engine blows up????
fwiw, i just looked at the factory tach wainting for install.....and there is no redline indicated.....go figger
http://www.picturetrail.com/gallery/view?p=999&gid=8253932&uid=3200195&members=1
MustangMatt1966
1,004
Orlando Fl.
Aug 29, 2005
#15
  • Aug 29, 2005
  • #15
haha they take it out, and beat the crap out of it till it wont go faster!
D
D.Hearne
11,730
south louisiana
Aug 29, 2005
#16
  • Aug 29, 2005
  • #16
Lets put it this way: you'll float the valves well before you reach the rpm limits of the bottom end. And that's IF it will rev to the point where it would float the valves ( this is all assuming it's still got the stock cam and valvetrain) Stock 302 bottom ends will survive occasional burst's to 6500 rpm's.( again, this is also assuming that the crankcase isn't sludged up and the oil pump is in good shape)
Max Power
1,774
St Paul
Aug 29, 2005
#17
  • Aug 29, 2005
  • #17
Usually lifter pump up and oscillating valve springs that are to weak to run higher will cause the float.
It's a natural rev limiter, and softer valve springs reduce friction and help cams and keepers last longer. That's a big deal if you are offereng your customers a warranty.
I also imagine that stock 302 exhaust port flow numbers have a little to do with it.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
